BDP-1 - Interface Down!
0 Members and 1 Guest are viewing this topic. Read 4819 times.
unincognito
    • bryston.com
Re: BDP-1 - Interface Down!
« Reply #20 on: 8 Sep 2022, 02:31 pm »
It says MPD is ON on the service page and yes I can play radio stations. I want to remind you that both my BDP-1's are behaving the same way.
Hi,
I dusted off my BDP-1 and powered it up yesterday and looks like one of the 3rd party programs that handles parts of the web UI requires a feature not found in the CPU used in the BDP-1's so it doesn't start and thus those parts of the web ui does not work.  In the mean time i've set the current beta(testing) release of the firmware to a version that doesn't contain the updated binary.
http://support.bryston.com/forum/viewtopic.php?f=44&t=248
Chris
Vinrouge
« Reply #21 on: 8 Sep 2022, 08:38 pm »
@ drummer.
my.bryston.com or mybryston.com....samee result.
And it is the ONLY webpage that won't open. Al others work on pc, laptop, tablet, cellphone etc.
hawkeye99
« Reply #22 on: 8 Sep 2022, 09:46 pm »
Hi,
Chris
I'm getting this after the update so I think it worked but I don't see any difference. I refreshed the page and then rebooted it......... I'm still playing with it.
I'm also losing connection for a second whenever I hit any navigation button. That was happening before and after the beta update.
"NOT BDP-1 compatible
If you've installed this on your BDP-1 you can install the current beta release
Installing test branch
We are working on a fix for BDP-1's"
freshaudio
« Reply #23 on: 9 Sep 2022, 01:06 am »
I've just update my BDP-1 with latest firmware "S2.45 2022-08-06" and "connection lost"
I can browse Qobuz album but cannot add to play. Local audio file can play from front panel button with no issue.
hawkeye99
« Reply #24 on: 9 Sep 2022, 10:53 am »
I got my music loaded. Totally different sequence that I normally did. I'll see if I can repeat the process on my second player.
hawkeye99
« Reply #25 on: 9 Sep 2022, 12:40 pm »
I got the second unit up and running.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #26 on: 10 Sep 2022, 10:42 am »
Jack Jorgensen
A shout out to Bryston audio!
I’ve spent a couple of days working with Bryston software engineers to resolve some connectivity issues between my wireless network and their digital player (my BDP-1) after installing a firmware upgrade that wasn’t quite compatible with my BDP-1.
Then today, I monkeyed around with my network sharing and adapter settings and lost my computer’s connection to the network entirely, so I ended up resetting the ip parameters and clearing and flushing the DNS cache and uninstalling / reinstalling my wireless network adapter drivers.
Meanwhile, the Bryston software engineers wrote and uploaded the latest patch to the firmware code that would be compatible with my BDP-1, incorporated a website link for the revised download, and sent me an email where to get it.  I tried the download and firmware upgrade again today and now everything works perfectly.
I have spent a lot of money (close to $40,000.00) on Bryston gear since 2007, and the electronic components are under warranty for 20 years, so it’s nice to see a company with this kind of customer support backing up the investment.
I cannot say enough about Bryston - a Canadian company, no less - and their products and after-sale service.
freshaudio
« Reply #27 on: 13 Sep 2022, 01:39 am »
Can you teach me how to solve this problem?
hawkeye99
« Reply #28 on: 13 Sep 2022, 12:57 pm »
I'll try but I'm not really available to do it until maybe the weekend.
hawkeye99
« Reply #29 on: 13 Sep 2022, 07:47 pm »
All I play are local audio files off a usb hard drive. I used the front panel like you did. What are you trying to do beyond that?
freshaudio
« Reply #30 on: 15 Sep 2022, 11:15 pm »
I mainly stream Qobuz and Tidal online music that BDP-1 can not play since that firmware update.
I tried beta but seem not do also.
hawkeye99
« Reply #31 on: 16 Sep 2022, 01:32 pm »
Sorry. Can't help you there. I don't use those features.
Vinrouge
« Reply #32 on: 16 Sep 2022, 05:48 pm »
Hail to Chris!
He called me and fixes all my connection and browsing problems online.
Realy nice man and verry scilled.
Thanks for the great support Chris.
hawkeye99
« Reply #33 on: 14 Oct 2022, 06:07 pm »
My BDP-1 freezes up after I pause it. Not all the time. Sometimes it'll be paused anywhere from 20 minutes to overnight before it freezes up and I have to reboot it. In the last week I've rebooted dozens of times. I've done everything I could think of on the network side but no luck. Any ideas?
hawkeye99
« Reply #34 on: 15 Oct 2022, 09:44 pm »
Clearing the dns cache seems to have solved the issue. Knock on wood.
hawkeye99
« Reply #35 on: 19 Oct 2022, 06:32 pm »
Nope. Back to square one. Still freezing up coming out of a pause.
Highendfool
  • It is what you think.
« Reply #36 on: 20 Oct 2022, 02:28 pm »
my.bryston.com is NOT CORRECT.
mybryston.com is Correct.
Both work. my.bryston.com is a secure connection,  mybryston.com is not.
hawkeye99
« Reply #37 on: 21 Oct 2022, 08:23 pm »
Ok. I switched usb ports in the back of the unit from the bottom one to the top one for my hard drive and it's been a couple of days since I've had to reboot. The hard drive may not have been seated properly in the usb port. I will try the bottom one again someday. Back to enjoying my music.  :thumb:
canuck5
« Reply #38 on: 28 Oct 2022, 07:54 pm »
I quit doing updates on my BDP1, seems like every time I do, I have issues.  Last time I had an issue didn't get much support from Bryston, a member from this site had same issue, he assisted me to correct the problem and no issues since,.
