DDC
0 Members and 1 Guest are viewing this topic. Read 1601 times.
mikedaniels
DDC
« on: 28 Aug 2022, 02:05 am »
Ok. I’m late to the table but I’m interested in digital reclockers. I bought a ifi purifier 3…it works!
Seams like a big gap to get to the next level (Sotm, Innous). I want usb out. Any suggestions?
rustydoglim
Re: DDC
« Reply #1 on: 28 Aug 2022, 01:04 pm »
We considered something like that and decided that if we did, we would sell a "snake oil" product. Sorry to be blunt, as this is a Nuprime forum, nothing against iFi, just that the so-called noise filter for USB doesn't work like that.
A possible solution is transformer-based isolation, which will be ridiculous because all good DACs are supposed to have noise isolation.
rustydoglim
Re: DDC
« Reply #2 on: 28 Aug 2022, 01:06 pm »
A $399 digital sampling rate converter and re-clocker would work not just for USB but other digital inputs.
madinaudio
Re: DDC
« Reply #3 on: 30 Aug 2022, 12:32 am »
Hello
do you plan to make a DDC RELOCKER like the Denafrips GAIA ?
Regards
rustydoglim
Re: DDC
« Reply #4 on: 3 Sep 2022, 07:34 pm »
Under consideration only.  By the way, many of our DAC products have built-in DDC Relocker already, such as DAC-9X, Stream-9, AMG DAC.
