building a new room
0 Members and 1 Guest are viewing this topic. Read 4185 times.
Big Red Machine
Re: building a new room
« Reply #20 on: 29 Aug 2022, 05:20 pm »
The room will dictate much of what you "should or should not" do. Suggest looking at the room modes your dimensions will enhance which may be detrimental to your enjoyment.
http://www.bobgolds.com/Mode/RoomModes.htm
Also, when looking at setting up the speakers in the room, Vandersteen uses a mathematical layout which mimics the audible walkabout Wilson Audio uses, most likely ending up in the same spot. In this manual is an explanation:
https://www.vandersteen.com//media/files/Manuals/treo_manual.pdf
Something at the first reflections, at least on the sidewalls, but also consider the ceiling - most chose absorption. I like diffusion but may change that on this upcoming room this fall.
Letitroll98
  • Too loud is just right
« Reply #21 on: 30 Aug 2022, 12:39 pm »
The Vanderstein method is similar to what I've been using for years.  The odd dimensions are close to the actual room antinodes, even dimensions are close to nodes (close is fixed by Vanderstein's suggestion to move by two inches).  I use a common 2d room node calculator instead of dividing room dimension by odd numbers and place the speakers between nodes and antinodes.  After measurement I find that it's always the most even response.
« Reply #22 on: 31 Aug 2022, 12:01 pm »
Would rather have a decent room with a $2000 system than a crummy room with a $20,000 system.
Monad
« Reply #23 on: 3 Sep 2022, 02:39 am »
i'll take the $20,000 system.  where do i sign up? ;D
tradubois
« Reply #24 on: 7 Sep 2022, 08:31 pm »
This is really interesting stuff.  I can't wait to try some of the things be suggested or put in.  Thanks for sharing
hififanatic
« Reply #25 on: 16 Sep 2022, 01:21 am »
Looking to build a music room in my basement and have read about using the golden ration that goes back to the Romans.  H=1, W=1.6, L=2.6.  Has anyone used this formula and how have the results been?
richidoo
« Reply #26 on: 16 Sep 2022, 12:13 pm »
Two very detailed articles about acoustic room ratios:
https://web.archive.org/web/20200928035856/http://forum.studiotips.com/viewtopic.php?p=5570
https://web.archive.org/web/20200224064931/http://forum.studiotips.com/viewtopic.php?t=3148
The original website is suspended, but the bots from arkive.org last grabbed it in 2020.
Also:
https://gearspace.com/board/studio-building-acoustics/743891-building-room-according-best-room-ratios.html
« Reply #27 on: 16 Sep 2022, 01:32 pm »
See my comments above.
Rob Babcock
« Reply #28 on: 11 Oct 2022, 07:38 am »
Yep.  I've said some variation of this for a couple decades. 8) :thumb:
