0 Members and 1 Guest are viewing this topic. Read 26776 times.
Drivers push as much sound into the box as out. The amount of echo and sound pressure in the box is extreme with the vast majority of it coming out via a port or bleeding through the drivers themselves. Yet little thought seems to go into the box shape. Cubes and spheres have to be the worse for echo. Stuffing and lining seem to be the only consideration. Single driver designs are the primary exceptions that use rear loaded horns, pipes, or transmission lines. Much finesse has been put into amplification and source design, even the drivers themselves. Why not cabinet designs? Instead we use cheap MDF and focus on veneers/finishes. The same could be said for the listening rooms. Thousands are typically invested in gear, just to end up in a horribly compromised space (the other enclosure). Rant off.
Well it depends on if you're speaking about mass market or not.
Exactly. Cost is the main driver. High-end speakers are where you'll find innovation in enclosure design. For most of us, painted or veneered MDF boxes are good enough and fit within most decors. If the cabinets are suitably damped and well-braced, it shouldn't be a problem.
Poor box design and poor integration into a typical listening space. Those 2 things plague box speakers. This is the primary reasons I switched over to high quality OB speakers and never looked back. Well, that's not quite true. After I got my OB speakers in the downstairs system, I DID go back to box speakers when I built out an upstairs system. And it was just as much of a disaster as it always is. Now I'm back to full OB speakers. Lesson learned.
I really find this entire bashing of box speakers a bit silly. Very well designed box speakers can sound.... excellent. Open baffle can also be great, but they don't have an exclusive grip on "best".
Open baffles are mindlessly simple....
