1.7i s Buzz
BikeFi10
1.7i s Buzz
« on: 10 Aug 2022, 02:01 pm »
 I just noticed a slight buzz at high volume on the back of one of my 1.7i s. The bass and treble were boosted high at the request of my wife. Go figure, dont most spouses say turn it down. Shes use to my old Kilpsch horned, ported towers.
Anyway, has anyone done diy repair on Magnepans?
The buzz seems to be in a small area about mid high to the back right.
EkW
Re: 1.7i s Buzz
« Reply #1 on: 10 Aug 2022, 05:43 pm »
When my 1.5s developed a buzz I was able to spot the region where the metal had pulled away from the membrane. Pusing on it would solve the problem for a couple of weeks. A little spray adhesive might do it, or a bit of light strong tape. Magnepan may have better suggestions on materials.
SteveFord
Re: 1.7i s Buzz
« Reply #2 on: 10 Aug 2022, 05:56 pm »
I hate working with glue as I'm too much of a slob.
Have you tried shining a powerful flashlight through there to see if the foil is delaminating?
BikeFi10
Re: 1.7i s Buzz
« Reply #3 on: 10 Aug 2022, 07:43 pm »
The buzz went away after I backed off on base and I havent listened since then.
If problem comes back Ill try the flashlight inspection. I dread pulling the sock off if I need to access it.
Yes, good idea to check with Magnepan if I need repair items.
tull skull
  • I can't send hare in search of anything!
Re: 1.7i s Buzz
« Reply #4 on: 11 Aug 2022, 05:47 am »
They actually have repair kits you can buy and I do think you can buy separate items like the glue.
