spade to banana post connectr
0 Members and 1 Guest are viewing this topic. Read 1729 times.
mr_bill
« on: 10 Apr 2005, 04:06 pm »
Hi Wayne,
Do you make a Spade (speaker end) to banana adapter (receiver end) so I can hook up my Kimber 8tc to my center channel speaker (spade end OK) and then to my Sony str da9000es (which doesn't accept large spades but does take banana ends)?
Bill
bubba966
« Reply #1 on: 10 Apr 2005, 04:53 pm »
He's made these up for the JJaz amps.
But they're not on his website. The only place they're mentioned is in the 6Moons reviews the JJaz amps thread. So you'll have to get in touch with him on ordering one for your center channel.
Wayne1
« Reply #2 on: 11 Apr 2005, 05:47 pm »
Those adaptors tha Bubba linked have 3/4" centers. Some of the speaker ouputs on receivers use a different spacing. I also made up some using single binding posts.
If folks are interested in these, I can put them on my website and build more.
They would go for about $30 for a single speaker.
tvyankee
« Reply #3 on: 11 Apr 2005, 07:51 pm »
hey wayne
do you make a spade to binding post so i could hook up speaker cables that have bananas on the amp end.
i have a amp with the really nice cardas screw down posts on the back and would like to use my nice banan end speaker cable with it.
thanks for your help.
Wayne1
« Reply #4 on: 11 Apr 2005, 08:27 pm »
Sure. No Problem.
There would have to be a small amount of speaker wire invloved.
Pricing would depend on what quality spades and binding posts you would want.
