BDA 3.14 not connecting to internet
0 Members and 1 Guest are viewing this topic. Read 2592 times.
steveoat
« on: 15 Jul 2022, 05:12 pm »
Have a BR 20 as well.  No problems with BR-20.  However, I can't seem to connect with BDA 3.14.  I get a timeout error and no connection.  Started a teamviewer session looking for remote support.  Is this what I should do?
steveoat
Re: BDA 3.14 not connecting to internet
« Reply #1 on: 22 Jul 2022, 07:48 pm »
I sent a PM to Chris but thus far no response.  Could someone please get back to me on this.  I can't do remote support since I am unable to reach the website.
Highendfool
  • It is what you think.
« Reply #2 on: 23 Jul 2022, 04:32 pm »
Are you connecting with the BR-20 but not the BDA-3.14?
Are you typing in “my.bryston.com” to access the internet from a browser?
steveoat
« Reply #3 on: 23 Jul 2022, 04:37 pm »
When I connect using mybryston.com, BR-20 connects fine.  However, I get the following message (regarding my 3.14):
Devices below this line were previously detected but are currently unreachable
Not sure how to fix this.
CHRIS I HAVE BEEN WAITING TO HEAR FROM YOU FOR A LONG TIME.  COULD YOU PLEASE LET ME KNOW WHEN YOU WILL BE ABLE TO LOOK AT MY UNIT?
Highendfool
« Reply #4 on: 23 Jul 2022, 04:41 pm »
I’ve had that happen. The router has assigned a new address. Just delete the shortcut and go through the browser and remake the shortcut again. Happens on power failures every time!
Highendfool
« Reply #5 on: 23 Jul 2022, 04:42 pm »
Did you email [email protected]? He usually is pretty good at responding.
steveoat
« Reply #6 on: 23 Jul 2022, 04:55 pm »
I checked the IP address and I am using the IP address the router assigned to the BDP 3.14.  I contact Chris both by email and my PM in this forum and no response.  Very disappointed.
Highendfool
« Reply #7 on: 23 Jul 2022, 05:02 pm »
The IP address showing under the “previously detected….” screen is the one that needs to be replaced.
Try rebooting??
steveoat
« Reply #8 on: 23 Jul 2022, 05:52 pm »
Try rebooting??
rebooted router and still shows the same ip address for the BDA 3.14.  Not sure what is going on.  BR-20 is still fine.
Highendfool
« Reply #9 on: 23 Jul 2022, 10:24 pm »
Did you try rebooting the 3.14 and the MPD ?
steveoat
« Reply #10 on: 23 Jul 2022, 10:36 pm »
The problem is that I cannot get into the screen you are showing.  I am stuck on the top page.  When I click, I get unable to connect error.  Is there any way to reboot the 3.14 without having to go into the web address?
Highendfool
« Reply #11 on: 23 Jul 2022, 10:39 pm »
Yes, power off, wait a minute or so then power on again.
steveoat
« Reply #12 on: 23 Jul 2022, 10:44 pm »
Tried this and still no luck.  I wish Chris would respond to my messages because he may know a solution.  Thanks for your suggestions.
Highendfool
« Reply #13 on: 23 Jul 2022, 10:47 pm »
Sorry I wasn’t any help.
Good luck and keep us posted as to what end’s up happening. As a fellow 3.14 owner, I’m very interested in why this would happen.
NekoAudio
    • Neko Audio LLC
« Reply #14 on: 23 Jul 2022, 11:51 pm »
Is the link LED on, at the Ethernet jack on the back of your BDA-3.14 and also on the Ethernet jack of your switch or router at the other end of the Ethernet cable?
Vinrouge
« Reply #15 on: 2 Sep 2022, 07:05 pm »
Same problem here. No response fron support. Manic moose gives a blanc page that is marked 'unsafe'. All the other stuff in my home and all sites on phone, tablet, pc are working fine.
christo
« Reply #16 on: 9 Sep 2022, 04:33 am »
Have you tried deleting the cache/memory from the browser you're using to access myBryston.com? That usually works for me when Manic Moose starts misbehaving.
Vinrouge
« Reply #17 on: 9 Sep 2022, 06:20 am »
Thanks for the tip. I do that almost every day or two. No result on this problem. It is the device, a had the same isseu ar my frien his home.
roonlistener
« Reply #18 on: 4 Nov 2022, 01:00 am »
Did you ever find a solution? I have a very similar problem. Thanks.
Vinrouge
« Reply #19 on: 18 Nov 2022, 10:15 pm »
Yes it got solved. Chris called me (in Belgium) and asked me to install a small program on my pc so he was able to take over my computer wich is connected to the player. He then installed new firmware and evertthing was fixed in a few minutes. Great job and superb service from Bryston! (Sorry for the bad english)
