Want a DVD/Bluray suggestion
Sinnyone
« on: 9 Jul 2022, 10:05 pm »
Hi all,
I have a Yamaha RX-V3900 and I want a DVD/Blueray/whatever else player to match up with it.  Doesn't need to be current, it can be around the same release date as the receiver, 2008 or so.  I figure, being around the same manufacturing date, there will be less interaction problems.  Built to work together you know.  Any suggestions?  Thanks
Jim
S Clark
Re: Want a DVD/Bluray suggestion
« Reply #1 on: 9 Jul 2022, 10:26 pm »
There are so many crappy Best Buy blu ray players out there.
But if you want to step up in dependability, look for a used Oppo.
Sinnyone
« Reply #2 on: 9 Jul 2022, 11:18 pm »
Im sorry, I should have mentioned I would prefer to stay with a Yamaha Player.  Something compatible with my receiver.
S Clark
« Reply #3 on: 10 Jul 2022, 01:45 am »
Your Yamaha receiver is only compatible with a Yamaha Blu ray player???  I'd bet that isn't correct.  However, good luck with your search.
