Hello!
HeadShake
Hello!
« on: 1 Jul 2022, 10:13 am »
Hi, group. I am in Creve Coeur. (is there a Gene in this group? I have met a local enthusiast through another site.)
I have some jbl 580 horns for a LCR hooked to an Onkyo. And I have a couple of systems I am designing that use hypex plate amps.
 For the last few months, I have been working on a far-field speaker for the living room. It uses a 15" woofer, 8" mid, and 1" dome with no baffle.
It is still a WIP but it will soon go from foam to wood.
Blackmore
Re: Hello!
« Reply #1 on: 2 Jul 2022, 03:33 am »
Welcome to AudioCircle from Wright City.
BPT
  • Balanced Power Technologies
Re: Hello!
« Reply #2 on: 2 Jul 2022, 01:06 pm »
Using the Hypes plate amps should make it easier and provide good results.
BPT
HeadShake
Re: Hello!
« Reply #3 on: 4 Jul 2022, 05:07 am »
Hey! You are just a little west of me!
I checked out your profile/system. Those lowthers look super cool. It looks like a full-range with no baffle.
Do you have a fav. speaker?
BPT
I dig them. The downside is they make me want to make many speakers since an XO becomes a file that I swap in and out instead of XO parts.
I looked at your pics too. The arrays look insane. Congrats on making something crazy!
sturgus
Re: Hello!
« Reply #4 on: 4 Jul 2022, 10:09 pm »
Welcome :D
Blackmore
Re: Hello!
« Reply #5 on: 4 Jul 2022, 11:15 pm »
I like the Lowther PM2A a lot but the PM6A that I have is a bit more forgiving in a no baffle scheme. Haven’t had them hooked up in years but I might dig them out for fun now that you brought it up. Crossover to a bass bin is around 300-325 Hz.
genestl
Re: Hello!
« Reply #6 on: 7 Jul 2022, 08:01 pm »
Hello Again,
I am here
Gene
vinyldavid
  • Collectorious Giganticus
Re: Hello!
« Reply #7 on: 10 Jul 2022, 07:13 pm »
Welcome to GAS!  There's a lot of speaker experimenters around here.
Hypex plate amps (and Hypex modules in general) are nice, very nice indeed.
Mr Peabody
Re: Hello!
« Reply #8 on: 12 Jul 2022, 02:46 pm »
Welcome to the group Headshake.
I use JBL in my system but definitely not a DIY'er
wedweb
Re: Hello!
« Reply #9 on: 17 Jul 2022, 09:48 pm »
Welcome to GAS.
Troy, IL here.
Bo
vinyldavid
Re: Hello!
« Reply #10 on: 18 Jul 2022, 02:47 am »
Welcome!
I used to be a speaker DIYer, but I gave it up.  Quality commercial designs make me happy enough to forget about most speaker projects.
There's a lot of us crazies around here.  Summertime is slow for most audio things.  I think I've heard about you from Gene!
