Line Force?
0 Members and 3 Guests are viewing this topic. Read 63204 times.
NoahH
Re: Line Force?
« Reply #200 on: 3 Feb 2023, 03:50 am »
As someone who once argued that Danny should listen to some of the newer DSP versions and then discovered how badly my DSP device was harming the sound, I will once more apologize to Danny for having doubted him on that front.  ;)
david45
Re: Line Force?
« Reply #201 on: 3 Feb 2023, 04:20 am »
In my case, I just try to keep an open mind as much as I can. I don’t doubt HAL has a great product (as well as a few others) and it’s only going to get better. Old school vs new school? I’d say both approaches have their merits.  :)
Montreal_Jazz
Re: Line Force?
« Reply #202 on: 6 Apr 2023, 03:44 pm »
Any development on the Line force? I kinda saw very quickly, in a video where Jay Iyagi visiting, a prototype of the new line force. Radian transducers? I'm pretty anxious to press the buy button and start building it! I have I bought the Italian walnut burl veneer already!  :D  Keep me posted! Cheers and thanks in advance.
Hobbsmeerkat
Re: Line Force?
« Reply #203 on: 6 Apr 2023, 03:54 pm »
That's not a prototype, or a new model.
That's a line force being used for a customer that will be using the GRS 10" mids, they aren't nearly as well behaved as the old BG units.
The line force is pretty much stuck on the back burner for now, we may pursue a new version in the future using the Radian drivers, but the cabinet will need to be redesigned to fit those drivers, as well as custom drivers, to keep the impedance load balanced.
We've got other projects we need to work on first, especially considering how expensive these will end up being, and will require a lot of development costs.
Re: Line Force?
« Reply #204 on: 17 May 2024, 12:26 am »
On a positive note, I'm in the process of building out a pair of Line Force's for myself.  Can't wait to get it all up and running.  Woot!   :banana piano:
« Last Edit: 17 May 2024, 09:11 pm by Tyson »
emailtim
Re: Line Force?
« Reply #205 on: 17 May 2024, 12:42 am »
What DSP were you using ?
FWIW, virtually all production music uses digital mixing and post processing.
jmimac351
Re: Line Force?
« Reply #206 on: 17 May 2024, 03:12 pm »
But..... where does it end,Tyson?
SpEaKeRs R FuN.  The more better the speakers, the more better...
NoahH
Re: Line Force?
« Reply #207 on: 17 May 2024, 04:41 pm »
MiniDSP SHD. I fully believe that some of the really, really, really good gear could do a lot better on it, but I am talking Theoretica and such.
As for mixing and such, there are a lot of issues with that as an argument.
1. Some of the really best recordings don't have it, but that is a very limited volume. Ex Octave's stuff and DSD from old tapes
2. Mixing and DSP are very different. Level mixing is simple. Parametric equalization is sometimes used in mixing but means the recordings had issues. Parametric timing changes are not done much at all in mixing. The latter two are in DSP, and are very complex and easy to screw up.
3. All the digital manipulation everywhere in the chain tends to introduce errors, and it adds up. I think a good analogy is freezing stuff. Sure - the fish you buy at the store has often been frozen before. But that does not mean that freezing it again at home and thawing it again is not going to make it worse.
HAL
Re: Line Force?
« Reply #208 on: 17 May 2024, 04:58 pm »
You might want to look at the Danville Signal dspNexus 2x8 system for DSP processor and crossover.
Danny and Scott heard it at LSAF2023 and both smiled.  :)
I already did a Line Force DSP crossover for them with the original dspMusik 2x8 system that Danny heard and gave ideas for improvements.  The dspNexus 2x8 with AK4499EX DAC's sounds better than its older brother dspMusik.
They are great sounding speakers!
mlundy57
Re: Line Force?
« Reply #209 on: 17 May 2024, 06:27 pm »
+1 I heard it at LSAF 2023 also. If I had room for another full system This would be in it.
mlundy57
Re: Line Force?
« Reply #210 on: 17 May 2024, 06:31 pm »
While I have to admit, I can't imagine topping the Line Force, it is said the largest room in the world is the room for improvement and who knows what driver technology will come up with next  :drool:
Re: Line Force?
« Reply #211 on: 17 May 2024, 07:07 pm »
So you are building a set of Line Force's??   They are amazing.
For my tastes, the Line Forces are the best I've heard.  By a lot.  I think there's nothing higher out there at this point.  So I think it ends here.  My only real question is do I go with all Miflex caps from the start?  Or start with a more modest crossover and change it over to Miflex after some time.  I'm leaning toward the latter option because it's more fun to experiment.
I am converting my Super 7's into the Line Force, so I get to re-use the Neo10 midrange drivers from my current speakers.  And I can re-use the Double Trouble OB sub drivers and amps.  For the Line Force I just needed new cabinets, a few new crossover parts and some new sub cabinets.  Oh, and tweeters.  Lots of tweeters.  32 in total.  Insanity.
If anyone is interested in building out their own pair of Super 7's, I am going to put my cabinets up for sale.  I'd love to see them go to a good home.
« Last Edit: 17 May 2024, 09:12 pm by Tyson »
emailtim
Re: Line Force?
« Reply #212 on: 17 May 2024, 10:48 pm »
You mentioned things can add up.  I agree and also stipulate they add up quicker when done in a haphazard way.
Math and processing has come a long way.  Math does not suffer from parts tolerance variances and age degradation.
Math and processing potential improves with age as history has proven.
I experimented with math and have a few examples below.
The best measuring DAC today is @ 130dB so to drive that DAC to its potential you need something cleaner than its maximum potential.
DSP can be done today in 16, 32, 64 and 128-bit, yet many tools chose lower precision math.
Here are some examples that I have tested:
Here are 4 FIR XO's processed in 32-bit ( 16-bit has a higher noise floor than -130dB so is already under-performing the DAC )
Note the noise floor of -140dB.  Just marginally better than the best contemporary DAC.
Here are the same 4 FIR XO's processed in 64-bit.
Note we are now down to @ -240dB, surpassing the best contemporary DAC's capability.
Now look at the same 4 FIR XO's processed in 128-bit.
Note we have now exceeded the precision of the display tool.
It is possible with today's tools to do all the math and convolution in 128 and 64-bit until the DAC's doorstep.
I would suggest the difference between good and poor DSP performance today is the choice and consistency of the filter and processing chain (using your favorite DAC du jour).
I have found some software tools to cut corners, thus avoid them accordingly in favor of ones that do not.
corndog71
  • Some people call me Rob.
Re: Line Force?
« Reply #213 on: 17 May 2024, 10:56 pm »
I was just going to ask if you were going to cannibalize your 7’s.  I’m terribly envious but look forward to your progress.  :thumb:
Early B.
Re: Line Force?
« Reply #214 on: 17 May 2024, 11:48 pm »
Of course!!! And they're on sale right now, so go for it!
Jaytor
Re: Line Force?
« Reply #215 on: 18 May 2024, 12:01 am »
That's great!  Did you find enough BG Neo10s or are you going to use the GRS or Radian drivers.
soundofrockets
Re: Line Force?
« Reply #216 on: 18 May 2024, 12:13 am »
Same question as above?
Re: Line Force?
« Reply #217 on: 18 May 2024, 12:18 am »
You are a bad influence  :thumb:
I found 4 of the Neo10's on eBay a few months ago, exactly the amount I needed.  Shockingly they were only $300 each so I jumped on it immediately.  Now that I think back, I bought the drivers before I even knew if I could get the Line Force cabinets made.  Just took a gamble.  Luckily it paid off!
Re: Line Force?
« Reply #218 on: 18 May 2024, 12:27 am »
Also I should give a shout out to Jay for working with me on the cabinets.
I have space limitations so I did some brainstorming with Jay and we came up with a custom design that will allow the Line Forces to fit in my space.
Danny Richie
Re: Line Force?
« Reply #219 on: 18 May 2024, 04:02 pm »
It sure would be nice if it were just about the numbers.
