Is STAX SRM-252 intended for the STAX Lambdas (from 1987), or not?
0 Members and 1 Guest are viewing this topic. Read 1605 times.
Sandbakk
  • Dipole is my choice of speaker construction.
Hello from Norway. I have a STAX Lambda SR-L300 from 1987, simplest version. Which still works, except that the original amplifier has stopped working, so I bought a used STAX SRM-252S DRIVER as a replacement. The problem is that the plug does not fit. The distance between the pins is smaller on the STAX SRM-252S DRIVER than on the headphones.
Is not SRM-252 intended for the Lambdas? Or has STAX changed the plug at some point over the years?
Anyone have a solution?
Thanks.
« Last Edit: 8 Jun 2022, 03:23 pm by Sandbakk »
Freo-1
Contact Birgir.    He is the Stax guru.
[email protected]
https://mjolnir-audio.com
Sandbakk
Thanks, good tip. I will.  :thumb:
SteveFord
Sandbakk
Aha, exactly, there I learned something new. And that means I'm stuck with a Stax SRM-252 that I can not use. Ok, my mistake, I'll try to sell it again. Thanks for the good info.
