OPAMP rolling orientation question
0 Members and 1 Guest are viewing this topic. Read 1503 times.
Sparky14
« on: 11 May 2022, 10:07 pm »
Not sure what is the appropriate forum to ask this....but since it is definitely cheap and cheerful, I'll try here
Opamp Rolling Question - so I bought some OPA1656 so go into my Aiyima A07 amp. However, it is apparently a SOIC chip mated to a DIP8 connector. OK fine. However it doesn't have a notch, so I don't know how to orient it into the DIP8 socket.
The pins are numbered. So, does the 1-8 side go with the notch, or does the 4-5 side go with the notch?
Sparky14
Re: OPAMP rolling orientation question
« Reply #1 on: 11 May 2022, 10:29 pm »
Ah found a diagram that had Pin 1 by the socket - and that worked.
