I'd appreciate your insights into (interim) preamp choices
0 Members and 1 Guest are viewing this topic. Read 4982 times.
rimljan99
« Reply #20 on: 11 Apr 2005, 04:00 pm »
Quote from: AKSA
In closing, yes, the TLP is a very good candidate for your purposes. There are two versions, the stocker at $AUD340, and the Nirvana upgrade at $AUD410. This component was the basis for further development resulting in the GK1, so it's pretty good quality. A couple of people here, most notably PSP (hi Peter!), have both the GK1 and the TLP and can give you a short comparison if you are interested in more information.
I am also interested in comparison between GK1 and TLP 8)
How long will last valves in TLP / GK1 ?
AKSA
    • http://www.aksaonline.com
« Reply #21 on: 11 Apr 2005, 10:48 pm »
Difficult to compare the GK1 and the TLP;  apples and oranges.  The GK1 is a full featured preamp, with source switching, volume control, gain, full dual mono construction;  the TLP has no source switching, no volume control, no gain, stereo design (both channels processed in the one tube), and a single power supply for both channels.
However, sonically, the GK1 offers much tighter bass, slightly clearer midrange and superior sound stage - I believe this is what you mean?
Tubes are under-run by design in both circuits;  total plate dissipation in the tube is under 1.6W, so I would expect a life in excess of 15 years.
Hugh
