Issues with new firmware update
0 Members and 1 Guest are viewing this topic. Read 2364 times.
Highendfool
  • It is what you think.
« on: 6 Apr 2022, 11:44 pm »
Anyone having issues with controlling Manic Moose or BDA3 with iPad after last firmware update?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Issues with new firmware update
« Reply #1 on: 7 Apr 2022, 12:20 am »
Hi - can you describe the area you are having difficulty with?
james
Clive197
« Reply #2 on: 7 Apr 2022, 10:54 am »
I thought we were told that all problems with Manic Moose and control on the BR-20 would be resolved in a few days. That was a week ago.
« Reply #3 on: 7 Apr 2022, 11:04 am »
We are waiting for ROON to allow us to post the new software
james
Clive send me an email and I will send you the latest software - [email protected]
Clive197
« Reply #4 on: 7 Apr 2022, 05:35 pm »
Thank you James, Adam sent the new firmware which I have now installed and verified. All seems good so let’s hope I’m not having to recycle the mains anytime soon. Let’s keep our fingers crossed.
« Reply #5 on: 7 Apr 2022, 05:51 pm »
Hi Clive - OK thanks for the feedback - the recycle is a strange one - I have 2 BR20's in two of my systems and have never run into that?
james
Clive197
« Reply #6 on: 7 Apr 2022, 11:26 pm »
james
Oooooo 2 BR-20s, someone must be getting them cheap. LOL
« Reply #7 on: 8 Apr 2022, 12:09 am »
 :thumb:
vonnie123
« Reply #8 on: 9 Apr 2022, 02:36 pm »
Hello James,
what is the latest Manic Moose release (both standard and beta)?  I have two BDP-2s:  I have S2.44, 11-26-21 on one, which I believe is a beta release, and S2.44, 10-5-21 on the other...mostly used as Roon renderers.  The first one mentioned has an attached BOT-1.
thanks...Robert
« Reply #9 on: 9 Apr 2022, 02:40 pm »
Hi Robert - yes the one you have is the latest beta.
There will be a new version soon which allows for ROON certification.
james
vonnie123
« Reply #10 on: 9 Apr 2022, 03:38 pm »
Thanks James...
----Robert
Highendfool
« Reply #11 on: 9 Apr 2022, 07:16 pm »
james
I was in touch with Chris and it turned out to be a remote issue with low batteries!
Sorry for the delay in replying.
