Linear power supplies can actually have a higher noise floor than a well designed SMPS. Benchmark has a white paper on the subject.
Atmasphere told me their monoblocks use toroidals.
Benchmark is actually my nemesis brand. I bought an AHB2 when I first got my Wilson speakers, and it was the most soul-sucking piece of gear I ever heard. The amps in my AVR sounded better.That experience made me not trust negative feedback any more and start to suspect power supply criticality after that. I am yet to find a counterexample.
Just checked their site and they indeed say toroidal! I can't see any innards but given their tube pedigree, I suspect they are serious.Definitely digging on that...
From your listening experience, maybe tube amps should be auditioned?
It's no secret -- the sound is in the power. Ask Jaytor about his Purifi amps with fully tricked-out LPS. Bottom line -- you have 2 options -- spend months or years rolling through several amps to find what you want OR realize that you'll never be satisfied and stick with an amp that's good enough.
I would also look at PS Audio M1200's and M700's. 1200wpc and 700 respectively.
If you don’t mind, I’m curious why you’d recommend these.
