WANTED!! Revelation Audio Labs DC umbilical cable
0 Members and 1 Guest are viewing this topic. Read 891 times.
mooncrikit
« on: 1 Apr 2022, 02:21 pm »
Looking to acquire one of these DC umbilical cords with an 8 pin configuration to work with my Gold Note PSU-10 EVO and Gold Note DS-10 Streamer, preferably in 1.5 meter length...
Not looking to pay MSRP :nono: :green: :...Thanx!
 :green:
« Last Edit: 5 Apr 2022, 03:48 pm by mooncrikit »
mooncrikit
Re: WANTED!! Revelation Audio Labs DC umbilical cable
« Reply #2 on: 2 Apr 2022, 01:26 am »
Great input Phil!...so being inactive affects my want of this cable how?...or shall I ask...your recommendations of other options otherwise?
Phil A
« Reply #3 on: 2 Apr 2022, 03:34 am »
All I can tell you is what is on the (Florida) State (corportate) records and what other people have claimed (e.g. https://www.google.com/search?q=are+you+a+victimof+brad+vojtech&oq=are+you+a+victimof+brad+vojtech&aqs=chrome..69i57j33i10i160.14325j0j15&sourceid=chrome&ie=UTF-8).  Per third party Florida residential records, he no longer lives at the address in his corporate filings.  Years back, I bought a couple of his Cat8 Ethernet cables and had limited contact and no issues.  He also likely (per my conversation with him) made the upgraded umbilical cord I have between my Modwright LS36.5DM preamp and its power supply I have for many years.  I believe Modwright has WyWires making them currently (http://www.modwright.com/modifications/modwright-truth-umbilical.php).  Don't really know what to tell you.  Other companies may make custom cables - e.g. https://zenwaveaudio.com/custom-cables/
JackD
« Reply #4 on: 3 Apr 2022, 07:32 pm »
The company is not inactive as I have communicated with Brad several times over the last month.  When a disgruntled member on another forum started this nonsense I tried to correct him with no luck.  He himself is the one who reported that the company was inactive when they didn't respond to his e-mails as fast as he wanted.  He is the one who contacted Google. Brad responded to me in less than a half hour. Chances of finding used ones are really slim though.  He is going to make a second Supratek umbilical for me when I get notice that the preamp is ready to ship.
Bob Stark
« Reply #5 on: 4 Apr 2022, 09:05 pm »
I have a Modwright Truth umbilical that sounds very similar to a Revelation.  It has the 2 holes near the end with 2 holes spread a little wider more toward the middle of the connector.  It is 47" long and is in 9 out of 10 condition.  Would this work?  I can't tell what the actual connection looks like on your cable.  This one is a bit on the short side however.
Bob
mooncrikit
« Reply #6 on: 4 Apr 2022, 09:11 pm »
No, it will not work as the Gold Note uses an 8 pin connector...But thanx anyways...Mooncrikit
