ATS Diffusers
0 Members and 1 Guest are viewing this topic. Read 3527 times.
Jaytor
Re: ATS Diffusers
« Reply #20 on: 12 Apr 2022, 04:59 pm »
Guys,
Just ordered my ATS Diffusers!  :D
Wig  :thumb:
Hope they work out as well for you as they did for me.
Wig
Re: ATS Diffusers
« Reply #21 on: 12 Apr 2022, 05:26 pm »
Guys,
Do the wells of the diffusers need to be oriented in a specific direction or should they look symmetrical when installed?
Wig
dpatters
Re: ATS Diffusers
« Reply #22 on: 12 Apr 2022, 05:51 pm »
I don’t think it matters. I tried both ways and it didn’t seem to make a difference.
Don P
Mariusz Uszynski
Re: ATS Diffusers
« Reply #23 on: 12 Apr 2022, 06:04 pm »
Guys,
Wig
When I was installing my acoustic panels, I was told by manufacturer (Vicoustic) to install them on the walls as symmetrical as possible.If you have a door on one wall, don't install panels on the other wall, across.I tried to put panels on the ceiling symmertical to the walls too.I have a designated hifi room, it's bit different.Perhaps, this may help.
Mariusz Uszynski
Re: ATS Diffusers
« Reply #24 on: 12 Apr 2022, 06:21 pm »
Wig, I still have a Vicoustic booklet with some general info and pictures.If you would like, I can take some pictures and e-mail you a booklet.Also, there is some interesting videos about room acoustics, just visit vicoustic.com, you never know it may help with your project?
« Last Edit: 12 Apr 2022, 09:55 pm by Mariusz Uszynski »
Wig
Re: ATS Diffusers
« Reply #25 on: 12 Apr 2022, 07:26 pm »
Guys,
Many Thanks
Wig :D
Jaytor
Re: ATS Diffusers
« Reply #26 on: 12 Apr 2022, 07:49 pm »
It probably makes a subtle difference, but I tried swapping a few of my panels and couldn't hear a difference, so I settled on setting them up symmetrically (mirror imaged left vs right).
