Bugle PS schottky dioode substitution?
0 Members and 1 Guest are viewing this topic. Read 1400 times.
vfrpilot
« on: 3 Apr 2005, 11:26 pm »
Digikey is out of the MBR1100 100v 1A Schottky diodes. Looks like mid may is next order date.
I have some 90v 1.1A diodes (11DQ09-ND) here at home from another project. Will these work ok in the Bugle PS?
hagtech
« Reply #1 on: 4 Apr 2005, 06:05 am »
I had designed the supply to use schottky types.  But there is enough headroom that it shouldn't matter, almost any diode will function ok.  I'll look for another replacement number.
jh :)
vfrpilot
« Reply #2 on: 4 Apr 2005, 06:42 am »
I think the ones I have are schottky types they are just a different voltage and amperage rated. I purchased them when I was modding my Art DiO dac.
I will just get some from Mouser I guess. They have the chassis I want to use anyway. Thanks.
hagtech
« Reply #3 on: 4 Apr 2005, 07:39 pm »
You can buy the "MBR1100RLOSCT", which is in stock.  Same part.  Something odd about DigiKey part numbering.
jh :)
