0 Members and 1 Guest are viewing this topic. Read 2942 times.
Glad to hear that the tube rolling worked out for you.I can almost guaranty that you will get more bass by replacing the obbligato golds with a better cap. It was a night and day difference between the clarity caps and the obbligato golds in the preamp that I built. The caps in the MP DAC are supposed to be easy to replace being held in by thumb screws if I remember correctly.Here is a review of capacitors-https://www.humblehomemadehifi.com/Cap.htmlMaybe Frank will contact me to review the SET 500.
I checked out the capacitor site, tons of info, very helpful, thank you. Great idea about looking into local mod.
