zaph audio zrt 2.5 cabinets
0 Members and 1 Guest are viewing this topic. Read 1443 times.
joegio
  • here we go again
« on: 17 Mar 2022, 02:42 pm »
Hi Folks,
I have the driver kits for this project. Was wondering if anyone out there built the cabinets for this ?
I wondering if maybe a step baffle would be in order. Also going to need to have a rear access panel as the x-overs are quite large..
I've built the proac 2.5 clones a while back, so sticking with scan speak one more time  figured Id give these a try.
Joe
rklein
  • My finest audio piece ever!!
Re: zaph audio zrt 2.5 cabinets
« Reply #1 on: 17 Mar 2022, 09:00 pm »
I built a similar design called the TRT by Rick Craig from Selah Audio.  The two links are his announcement of the TRT model and my build thread.  Not sure if this helps but thought you would be interested in a design that is based off of the Zaph zrt model.
https://www.audiocircle.com/index.php?topic=58819.msg522118#msg522118
https://www.audiocircle.com/index.php?topic=71964.msg857611#msg857611
joegio
  • here we go again
« Reply #2 on: 18 Mar 2022, 12:42 am »
Thanks !
