0 Members and 1 Guest are viewing this topic. Read 8827 times.
Is it me or is anyone sick of bad mixes that you can't hear shit on... all for a picture difference that doesn't seem particularly appreciable...
You probably need to go into the setup menu for your blu ray player and set the audio to default to stereo if you are running 2 channel or the TV speakers.
Already done. A bunch of these Blu Ray's just don't have the track for it. Maybe an external processor could do a better job, but if you have one of those you already have surround sound...
I have a Sony 4k bluray player that has an optical out that I use to plug directly in to my 2 channel DAC, I run stereo not multichannel in my setup and it sounds great.
I’m now very confused about the whole point of this topic. If you don’t care about picture and sound quality why even post here??With a few hundred Blurays and even more DVD’s it’s easy to say that DVD’s are noticeably lesser in both sound and picture quality. Even streaming is almost always better than DVD in picture quality and at least equal in sound quality. Obviously not all BD’s take advantage of everything the format offers but that is not a reason to ignore the benefits. Audio dialog can sometimes be a problem with movies but most BD players offer options to compress the sound which almost always solves that problem. OTOH, if picture and sound quality are not priorities then you certainly shouldn’t bother with Bluray.
