New rave review of our new Digital preamplifier
0 Members and 1 Guest are viewing this topic. Read 3423 times.
avahifi
    • http://www.avahifi.com
« on: 26 Feb 2022, 01:03 am »
Go to Parttimeaudiophile.com and enjoy.
Frank
firedog
Re: New rave review of our new Digital preamplifier
« Reply #1 on: 26 Feb 2022, 08:05 am »
Hi-
Sorry for the silly question, but how does the volume control work on this?  I assume it has a remote with VC?
It isn't mentioned in the reviews or on the product page.
Meicheng
« Reply #2 on: 26 Feb 2022, 08:12 pm »
I think you can control the volume from the touch-screen and by the remote.
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #3 on: 8 Mar 2022, 02:47 am »
The PTA review is under Components, not Digital as I first searched. I agree, magnificent clarity is the first impression I had.
Yes, the volume is controlled either by the remote or by the touchscreen. Can't answer the how, without opening up the case.
I'm still using my DVA Digital Preamp as a DAC, with the output connected to my analog preamp input, so I can also control the system volume with my analog preamp volume control. I do have a D2A which I haven't connected yet. I can tell you I am thoroughly enjoying my digital preamp and am glad I waited for it!
mr_bill
« Reply #4 on: 2 Dec 2023, 04:55 pm »
Anyone know what the volume scale is on the DVA pre (0-?)?
Also what increments does volume increase by 1 or 0.5, or?
NIGHTFALL1970
« Reply #5 on: 3 Dec 2023, 02:53 am »
Not sure what the scale is but I listen to most music and movies between 45 and 50. That is plenty loud.
mr_bill
« Reply #6 on: 3 Dec 2023, 04:54 am »
Thanks nightfall, how do you like your DVA Preamp?  It has some great reviews!
NIGHTFALL1970
« Reply #7 on: 3 Dec 2023, 04:34 pm »
The DVA is now the best preamp I have ever had. No more hiss in my speakers. It’s that quiet. I hear details that I never heard before. Vinyl sounds better than ever!👍
Digi-G
« Reply #8 on: 4 Dec 2023, 01:29 pm »
You know, a link to the actual product or even a model number would be really helpful.  I don't know exactly what I'm searching for.
Phil A
« Reply #9 on: 4 Dec 2023, 01:54 pm »
https://parttimeaudiophile.com/2022/02/25/van-alstine-dva-digital-preamplifier-review/
danielgk
  • AVA engineer/technicion
