.7 | Modern Factory Stand Installation
0 Members and 1 Guest are viewing this topic. Read 1086 times.
firewall
  • None
« on: 21 Feb 2022, 10:01 pm »
Dear .7 owners with the modern stands:
Please note: this is for the modern acrylic stands, not the standard stands -
I just got .7s back from the factory but the bolts for the standoffs do not fit?! They are now too thick, somehow?!
They are the same bolts I used when I sent my .7 to the factory.
Now they are too thick to fit into the metal threading in the speaker.
Any thoughts/suggestions, please?
Do I need to remove something from the inside of the speaker for these to fit? I don't remember, and Magnepan sent no instructions.
Thank you for reading.
**** Solved****
Magnepan puts little 'ends' on the mounting holes to line up with the mounts. I removed the ends, and it all worked.
« Last Edit: 22 Feb 2022, 03:34 am by firewall »
