0 Members and 5 Guests are viewing this topic. Read 47173 times.
Hi: If you're getting some garbled sound out of the speaker, it's likely the power supply still has some/all of the voltage. When you short the speaker cable, the output FETs on the amplifier board normally short out on one side or both. Since the sound is garbled, one pair of FETs may be okay and the other pair shorted. A few years ago, I bought a bunch of FETs, matched them, used for my failed amp, and sold many to users that had failed FETs. I don't have access to my stash of matched FETs right now.The AOB416 FETs were discontinued by the manufacturer but some supply houses may have some. I bought a reel of 100 from a decent supplier in China.If you find the power supply is dead, you can likely replace it with one similar to the SMPS800RS. Audiophonics.fr has some listings. https://connexelectronic.com/product/smps800rs/ has various models.Bob
You might be bored with my power supply saga by now but having dismantled it and checked the underside of the board ...I am now confident this is what I need https://connexelectronic.com/product/smps800rs/and I have duly orderd from connex. Sadly https://www.audiophonics.fr/ didn't have the 230VAC, 60V option in stock. They did have the RE version but a quick google established that would not be an appropriate replacement.The price in USA + shipping was similar to that from France + shipping, so went for the exact supply and voltage from connex.I also took a good look at exactly what I would need to do to fit the new supply into the original box from DAC and it looks straightforward (famous last words!).I will let you know how I get on.
