New Amp For Omega Alnico JR XRS
0 Members and 1 Guest are viewing this topic. Read 6090 times.
Kray
Re: New Amp For Omega Alnico JR XRS
« Reply #20 on: 31 May 2022, 09:52 pm »
The REL T5i is excellent choice. I was using one for the longest time then got a deal on a second one. So have two for left/right. You can barely tell they are on but they seamlessly add the perfect amount of low without being boom/bass’y
Delta77
« Reply #21 on: 1 Jun 2022, 03:24 am »
That’s a good looking amp.
Hope your enjoying it..
audiomaniac
« Reply #22 on: 1 Jun 2022, 04:57 pm »
Hi Delta, yes I am enjoying the amp very much. I had it wired in triode and while the EL34 isn't a triode tube I like how it sounds. Plus it's cheap to re-tube! I recommend Analog Ethos and Perry was great to work with.
