BDA-3 VS BR-20
0 Members and 1 Guest are viewing this topic. Read 853 times.
bacmsl
BDA-3 VS BR-20
« on: 13 Feb 2022, 02:18 pm »
Are the DAC'S in the BDA-3 the same as the BR-20 or are the DAC'S in BR-20 upgraded?
Barry M
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-3 VS BR-20
« Reply #1 on: 13 Feb 2022, 03:46 pm »
HI Barry
Identical.
james
spartana
Re: BDA-3 VS BR-20
« Reply #2 on: 13 Feb 2022, 09:55 pm »
Hi Barry, the dac may be identical but I can tell from my experience that a br20 sounds more refined than  bda3 in combination with a bp173. I traded in the combo to get a br20 after listening to a test sample. No idea why it sounds better with digital music if the dac is identical but it definitely does... says also my wife. And she definitely does not hear a better sound because she longs for the newer amp.
Re: BDA-3 VS BR-20
« Reply #3 on: 13 Feb 2022, 10:43 pm »
HI,
I think it that situation you are listening to the differences in the preamp sections between the BR20 and the BP17.
