Help! How to remove/refit battery in BDP1
0 Members and 1 Guest are viewing this topic. Read 1024 times.
Norton
« on: 12 Feb 2022, 05:22 pm »
I need to replace the motherboard battery in my BDP1.  Seems to be in the cream plastic housing quite firmly with slight  lip to keep it in place.  I don’t want to apply too much force.  How have others got it out and replaced?
Spyman
Re: Help! How to remove/refit battery in BDP1
« Reply #1 on: 12 Feb 2022, 11:14 pm »
I recently had to do this. I just applied increasing upward pressure until the battery came out. Then I put the new battery in, making sure the plus side was facing up, and pressed down until I was sure it was seated properly. Hope this helps.
vonnie123
« Reply #2 on: 13 Feb 2022, 04:29 am »
Done it a couple of times. Be careful with respect (no static) to grounding inside the component.  Apply light pressure to the battery upward from one edge.  It should pop loose.
Norton
« Reply #3 on: 13 Feb 2022, 10:33 am »
Thanks, I did just try gentle upward pressure but I couldn’t get it to move and was afraid of more force pulling the holder off the board.
In the end , I pushed out  one rear-facing corner of the plastic holder with a small screwdriver, just enough to then pull part of the battery over the retaining lip,and then pushed the battery gently up  from below with the screwdriver.
All refitted fine, however I still got “09” error on initial boot, but disconnected and reconnected power and usb cable and now all seems fine.
vonnie123
« Reply #4 on: 14 Feb 2022, 05:40 am »
Glad you got it going.  I've also had the 09 error code, and Chris Rice walked me through a connect-disconnect-reconnect procedure on the serial cables.  Apparently they may get corroded or loose over time.
