Another PS question...
0 Members and 1 Guest are viewing this topic. Read 1146 times.
sfox50
« on: 1 Apr 2005, 07:27 pm »
Should the heatsinks be soldered to the board? There is mention of using #4 washers to isolate the heatsinks from the board-?? :?:
hagtech
« Reply #1 on: 2 Apr 2005, 01:03 am »
Yes, solder in place for strength.  The washers are added to make sure the heat sinks do not break through the solder mask insulation and short to a trace.
jh :)
sfox50
« Reply #2 on: 3 Apr 2005, 01:18 am »
Jim- thanks for all the help- the Power Supply is working just fine- I'll never need to re-charge the 12 V. cordless drill batteries I was using again! :lol:   ( I need the drill again,too!!) Now to chase down the hum I get at volume- I think it's in the Foreplay...
