0 Members and 1 Guest are viewing this topic. Read 22218 times.
...I thought I'd done them all but I just found an un-modded one. I'll P&S it first thing tomorrow. .....
Occam: Happy April Fools Day.Larry
a) what is the point of having shielded PCs when the rest of the house wiring is unshielded (I understand some of you folk in the USA have your house wiring inside earthed metal conduit? ... we certainly don't in Oz!)?
b) what are the pros & cons of shielding each core (ie. A, N & E) vs. shielding the overall 3-wire cable like the Volex does?,,,One point I can think of, that a "good" PC should have (apart from the obvious ... thick conductors to minimise resistance), is low inductance - again, to minimise any dynamic force acting against the current flow ... particularly as it happens in milli-second, high-current bursts!
I wonder if the Volex is tightly twisted inside? I suspect if one got hold of the same guage, mains-rated wire as in the Volex and simply braided the 3 wires together, you would end up with a PC which has lower inductance - and is therefore, theoretically "better"!!
Andy ... I simply don't see any technical benefit to not increasing shunt capacitance while minimizing series inductance ...
