Two woofers in the same bass cabinet are in phase with each other ?
gogg
Hello guys!
I soldered the internal wires to the drivers but  started to wonder what if I made mistake and screwed  the phases/polarity.
I did the test with 1.5 V battery positive pole to the positive speaker connector and all drivers (except the tweeter offcourse) goes out a little bit, not in.
Would any one of you 938 owners be so kind to do this test and report it here?
Especially: are the two woofers in the same bass cabinet in phase with each other ?
Thank you!
Hello guys!
Thank you!
I dont own this speaker but If one of the woofers is out of phase the sound will have little volume/SPL easy to detect.
« Last Edit: 2 Feb 2022, 01:43 am by FullRangeMan »
gogg
To answer my own question:
Yes they are!
Rusty Jefferson
Similar woofers in the same chamber would have to move the same direction from a positive battery charge on the +/red connector on the cabinet. Perhaps someone can confirm they (all) move out on the positive charge to +/red as some speakers are wired to pull in on a positive charge to +/red by design.
