Platform mods? What do you use to block resonances?
Bob2
Re: Platform mods? What do you use to block resonances?
« Reply #40 on: 17 Feb 2022, 02:44 pm »
Hey Phil and Bob,
Do you guys run long interconnects or speaker cable?
Would love to hear your experiences. Thanks
I have both speaker cables and interconnects. Originally, I had my amp located with the rest of my gear. 23 foot, 10 ga. speaker cables. Sound was great. After reading a post by James Tanner responding about what to use, speaker cables or interconnects for longer runs. He explained that longer IC run would be better. So, I ordered a pair from Bluejeans to try out. Moved the amp to the other end of the room. Been in place for about a month and while there isn't a big difference, I do think it is better.
