0 Members and 1 Guest are viewing this topic. Read 7212 times.
Maple platform from Mapleshade sitting on IsoAcoustics Iso-Pucks. Don P
I site both my tables on a maple butcher block platform with these underneath:https://www.supplyhouse.com/DiversiTech-MP-2E-EVA-Anti-Vibration-Pad-2-x-2-x-7-8Simple. Effective. Cheap! Passes Fremer's knuckle rap test (as described by BobM above) with flying colors.
No idea about the technical aspects of these pads. I don't care. I just try stuff, and try not to overthink it. It either works or it doesn't.My tables don't skip even if I do jumping jacks in front of them, there is no airborne feedback, and they pass the knuckle rap test, so I'm happy. It helps that one of my tables (Townsend Rock mk3) has an air bladder built into it. The website / seller I linked earlier does have them in different sizes and materials, as you mention.https://www.supplyhouse.com/Pads-11752000Even though they are not necessarily designed for audio use, the reviews show that many guys successfully use them for that purpose.
those pads will help you, yet all I was offering was a direct source. The guy on Ebay is ripping people off. Then I said something about the weight factor. They sell different ones for different weight placed on them. Some people have a lot of mass in their setups and some don't. glt
Rotarius:"Every audiophile worth a damn knows to use metal or carbon cones for vibration control. Add a jar of machine dynamica pebbles behind the listening position for maximum effect. The idea is to employ quantum resonance schema to neutralize the system resonances. Perfect for turntables."Were you just drinking, or also imbibing PCP when you created this brilliant & unique manifesto?I think it was the latter...IN any event, cheers!
The shelves on my stand are actually seismic sinks with 50lbs of sand in each shelf. A maple board floats on top of the sand. But that's not enough for the turntable. It's plenty of mass but doesn't completely isolate it. So I sandwich another maple board on top of that and separate the two boards with a bunch of squash balls, kind of like a Ginko isolation device. I find that the rubbery isolation coupled with the mass it all sits on does the job nicely. Here's a test. Put the tonearm down on a record but don't spin the platter. Now tap your knuckle on your shelf and see if you can hear that thump through your speakers. If you can, then you don't have enough or proper isolation. Yeah, this is an exceedingly difficult test to pass so don't be surprised when you hear that knuckle rap quite plainly.
Agree with you 100% on the tweak rip-off artists. Plenty of guys selling these online for jacked-up prices (including Amazon) not just that guy. Mapleshade Audio has the cork ones jacked-up at more than 20X the price. Disgraceful!https://shop.mapleshadestore.com/Mapleshade-Isoblock-Sets_p_1224.htmlI bought mine several years ago from that vendor I linked. Don't remember the exact count but I bought an entire box of 30 or so, and they were super cheap on a per unit basis. (I don't see the bulk boxes on the website anymore).I'm actually not sure how much these pads are helping. I think a big part of the resonance control is that my DIY rack is very solid / heavy / rigid, made with maple butcher block and 80-20 extruded aluminum. My avatar shows it, and other photos in my Gallery if interested.
