Advice Needed - Newbie Headphone User
0 Members and 1 Guest are viewing this topic. Read 2086 times.
Horizons
« on: 31 Mar 2005, 12:02 am »
OK, so I have been listening to my Sony Discman and Grado SR60s for years. What is a moderate step up while only spending $100-200 or so?
I am moving and my high end rig will go in storage for six months or so, that means headphone listening is IT for a while.
Headroom amp, new phones, new player? I have no clue.
Thanks.
BradJudy
« Reply #1 on: 31 Mar 2005, 01:16 am »
A couple of important questions:
Do you like the sound of your Grados?
Is remaining portable important?
Horizons
« Reply #2 on: 31 Mar 2005, 05:09 pm »
Quote from: BradJudy
Yes and yes!
Thanks.
BradJudy
« Reply #3 on: 31 Mar 2005, 06:10 pm »
You might want to try the Grado SR-225s.  They are $200 list, but you should be able to get them for less, or get them used for ~$150.
There aren't a lot of portable amp options.  The ones that come to mind are the Headroom Airhead and the Xin Supermini.  Or, you could get something like a PIMETA from JMT - http://jmtaudio.com/  it looks like he has a couple of demo ones already built for $110.
I don't know anything about portable CD players.
djbnh
« Reply #4 on: 1 Apr 2005, 02:41 am »
Horizons - try doing a search at the following: www.headfi.com
