0 Members and 1 Guest are viewing this topic. Read 4579 times.
A $100,000 Klippel machine will tell you, but so far I'm about $99,000 short of acquiring one.
That pretty much says it. Offset drivers were thought to be best practice back in the day. The idea was that diffraction peaks and dips to one side of the speaker would be different than to the other side, and would tend to offset each other in the overall room response. I don't think there were ever any blind, controlled tests to see whether the theory actually made any audible improvement. I never heard any between the old BMR's and the new in-line--they sounded the same, perhaps because the drivers were so smooth off axis to begin with. Today, following the research of Floyd Toole and others, the design goal is even off-axis response to either side of the speaker. That's tricky and requires very careful selection of drivers and crossover points, or resorting to a wave guide for the tweeter (which has problems of its own), but at least the designer can tell whether that' objective has been met by performing the proper off-axis measurements. With offset drivers, you never know what you've got off axis, because the response to one side will never be the same as the response to the other side. My current Affordable Accuracy monitor uses a very old-school Parts Express cabinet with offset tweeters, and I went crazy trying to optimize its response. A $100,000 Klippel machine will tell you, but so far I'm about $99,000 short of acquiring one.
Audio Circle should crowdfund or gofundyou a Klippel.
I'd like one too!- Jim
The good news is that you can send any speaker to Erin at Erin's Audio Corner to measure for free. https://www.erinsaudiocorner.com/
+100.Actually you should crowd fund/go fund the shipping. That would help in and of itself. But like Jason alludes, it's terribly important to have good honest data and that the klippel will show especially with Erin at the helm.Best,Anand.
Thanks for explaining the driver alignment question. I am really interested in a speaker implementing the RAAL tweeter, and have been stalking the used market for a pair of curved cabinet BMR monitors. Failing that, I may just go whole-hog on a gorgeous pair of Jim Salk's many offerings.
