Hi Elizabeth, thank you for the info along with the the link. I'll be sure to check it out.Saturn94, you did read that correctly. While researching, I came across a thread where someone had an arching situation. Turned out it had something to do with the jumper plate. I've also read of where some individuals had sizzle here and there. Weird! I was sitting at my computer the other night which is near the left speaker, the one incorrectly wired. Heard this loud pop/bang that just about made me jump out of my skin. Thought it may have been the ductwork but I swear it came from that speaker.It was disheartening that the tech didn't offer to replace them as I'd hoped. Sigh! Wrote the salesman the other day but haven't heard anything. The store is closed Sunday and Monday. Hopefully he'll get back to me tomorrow. Shipping is high being I'm on the east cost. Steve, I'll be sure to post if there are any changes. I'm disheartened about the whole thing and quite skeptical. I swear if it weren't for bad luck I wouldn't have any luck at all. Don't mind going through the break-in process if I knew for sure I had something to work with. This isn't impressing me as first time customer of their product(s). The guy didn't ask for serial number or anything. When I mentioned I have about 400 or so hours on them, his response was, "Maggies take 3-4 month to fully break-in". So I'm hoping the sales person will come through for me. Otherwise, my initial intentions of purchasing a smaller set to run HT at some point will be a no go!
Sorry if I missed this somewhere, but what does MLP stand for?
If you find them too bright, buy a pair of Mills 1 ohm and 1.2 ohm resistors for the tweeters. https://www.partsconnexion.com/MILLS-71901.htmlThey are much better than the crappy sand resistors that come with the speakers. Those sand resistors introduce noise. The Mills add some warmth and they sound clear.I have a pair and but prefer these Duelunds but they are expensive-https://www.partsconnexion.com/DUELUND-74958.htmlI find that they have a more transparent sound. I would buy both and see what you prefer. I found that the Duelund 1.2 ohms work best on my Magnepan 1.6's. However, you can always go up to 1.5 ohms or down to 1 ohm.
Sent an email to Wendell. Received a reply from him earlier to let me know he is "no longer" with sales and marketing. He told me the email has been forwarded to Mick in their service department.As for the speakers, I was adjusting toe-in last night. Listened for a bit and tried adjusting again to try to bring out the bass a little more. When I returned to the MLP, I was taken by the surround sound. I was completely immersed. Couldn't really tell L/R and the speakers disappeared. In all my audio years, this is a first for me.
I must be nuts because I tried some Deulands, didn't like them, and went back to the Mills!
