Thank you for the toe-in suggestions. Update:Called their service department this morning. The gentleman whom i spoke with told me I should be fine with leaving the polarity reversed. He told me if were to either have any other questions or issues to contact him via direct line. Also to contact the dealer and they would arrange something.I mentioned of how I had a loud pop a few days back... that just about made me jump out of my skin as I was sitting next to one speaker. He told me the foils may arc as the film stretches. lol He told me about the only things that can go are either the fuse will pop or a broken foil which will take out whichever section it may happen with or if they bottom.So as this point I'll keep my fingers crossed and keep playing with the actual placement within my means. Have to order longer balanced cables after the holidays along with getting some 10awg cable. I'll also snag an assortment of Mills resistors to try as well until I find correct value.One last question: Do any of you know for a suitable diy project for both damping and defusing. Thank you.
Hi Davey! Read a few of your posts here as well as other forums. Hope things are going well.
