0 Members and 1 Guest are viewing this topic. Read 7869 times.
Thanks for the review and comparisons! What kind of power supply were you using for the 15v?
I decided to give this a try, and it just arrived yesterday. Set it up, but couldn't find the right cable to connect to the variable voltage output from my HDPlex power supply. So I decided to try the fixed 12v output instead, since I did have the right cable for that output. It works on 12v!I had a suspicion it might, as the particular circuits in computer/network/digital devices often run at much lower voltages served by various voltage step-down devices along the way. I figured the 15v input might be that particular voltage simply because the A20d is designed to pair with the A20a amplifier, which uses a 15v input and has a matching 15v output to run the matching DAC, making it very convenient for those who want both units and plan to stack them or use side-by-side. A 15v input makes much more sense for an amplifier, which is more demanding of power than a DAC. But just because it's designed to be paired with an amplifier in such a way, it doesn't mean the internal circuits of the A20d actually need 15v themselves. And sure enough, 12v works just fine.Just thought you folks might be interested to know this fact, as it opens up a whole other range of low noise power supplies. I haven't tried any lower voltages than this yet, but may eventually do so. I also don't know if the device draws more current at 12v than at 15v, which could potentially be the case. In general, I don't think trying lower voltages is dangerous or potentially damaging to the device. It would be voltages above 15v that would be the problem there.
Another question - how much have you played around with the different filters, and do you have a preference for one over the others?
Hmm, interesting regarding current increase. Do you know if it increases proportionate to the voltage drop? I.e. 12v is 80% of 15v, so current is 1.25x at 12v vs at 15v (1.25=1/0.8 )?
Like Sparky14, I didn't know about the power supply issues in the D5. Fortunately, mine hasn't had this issue <yet>. Of course, mine sits in a box for 6 to 8 months each year. I'll keep an eye on it the next time I use it.I'm glad you mentioned it, wushuliu.
I’ve had the Sabaj in my TV system for the past couple weeks. It gets 5-6 hrs of use per day between the family.
