Pure Vinyl Bookmarks and new Macs
rbpeirce
« on: 6 Dec 2021, 02:04 pm »
For better or worse, when I started to use Pure Vinyl I used the bookmarks and 192kHz sampling.  Since then I have not been able to move beyond Mojave.  Now I have to and the software is not compatible.
What I have is the original caf files and the bookmarks, which are loaded into iTunes.  I can actually play a caf file but it has no information about the contents.  Is there any easy way to make this stuff useable on a newer Mac?
I have the option of using Pure Vinyl to create individual playable tracks which I could load into iTunes or some other program but that would take a really long time.  I have over 10,000 tracks.
What would be ideal is a program that can work with my existing files.
