Speaker Cable Recommendation
jtcf
Re: Speaker Cable Recommendation
« Reply #20 on: 1 Dec 2021, 01:32 pm »
I'll look forward to your impressions. For me ZenWave cables have been like fitting in puzzle pieces.One design may be perfect between amp and pre but be a bad fit from dac to pre.But another from the lineup turns out to be "the one".
DaveC113
  • ZenWaveAudio.com
« Reply #21 on: 1 Dec 2021, 04:51 pm »
Hi @minatophase3
I also had the DSR XLR available so I put that in the box too.  :D
What @jtcf mentioned is true, while I try to achieve the maximum clarity and resolution for every ZenWave cable, tone is very different! The "right" tone can vary a lot from system to system and from person to person. This is why I offer 3 different high-end interconnect cables, from the pure silver DSR to the silver/gold D4 and the silver/GOLD D5.
With speaker cables I think the results are more dependent on electrical characteristics, speakers typically have an impedance of 4-8 ohms where components are usually over 10,000 ohm and often over 100,000 ohm. So the speaker cable carries a lot more current (and usually a lot more voltage) and so more energy is stored in the EMF or electro magnetic fields. Reducing inductance by using flat wire and/or specific and special geometries reduces energy stored in the magnetic fields and makes for better performance. The combination of the electrical characteristics of the SC + the speaker is best when it presents the amplifier with an ideal load, in fact in some amps excessive cable capacitance can cause instability and amplifier damage. So we're not looking for the least inductance at the expense of having far too much capacitance, and imo it's best if this can be achieved without correction networks, and this is the reason my ribbon cables and litz cables are superior to cables that use traditional round wires.
That said, you're also at the mercy of the speaker designer, I feel like many crossovers are designed without any consideration for the amps and cables used to power them and this can make it so non-ideal speaker cables may be more ideal for a particular speaker. It's likely that if every speaker had crossovers with impedance correction and then used an electrically ideal cable that the selection of speaker cables would be much more straightforward.
Mariusz Uszynski
« Reply #22 on: 1 Dec 2021, 08:19 pm »
I'm sorry for the mistake.I hope I did not start the war.
« Last Edit: 1 Dec 2021, 10:28 pm by Mariusz Uszynski »
minatophase3
« Reply #23 on: 1 Dec 2021, 08:36 pm »
Hi @minatophase3
Thanks Dave, looking forward to hearing all 3 of them as well as the speaker wires!
minatophase3
« Reply #24 on: 1 Dec 2021, 08:37 pm »
My system is pretty basic so I only need one set of XLR's which makes the puzzle a bit easier to compete :-).
zacho
« Reply #25 on: 29 Nov 2023, 09:13 am »
I am going to demo some of the SCR-11 speaker cables as well as a D4 and D5 XLR, very excited to give them a try!  Have some friends coming over this weekend to hear them as well.  Based on what I have read about them, think they will impress!
Tim
Hi Tim,
Any recollection of your impressions of the various ZenWave cables you tried?
