AV123 Onix Rocket RS250 MK II pair
0 Members and 1 Guest are viewing this topic. Read 1117 times.
Nick77
« on: 19 Nov 2021, 02:39 pm »
AV123 Rocket MK in rosewood finish with black high gloss tops.  $100 plus shipping (Pickup local to Austin - Free!)  The tops do have scratches but depending on the angle you can't see them and there are snags in the fabric front  But they sound sweet!
Specifications
● System: Two-way, two driver direct-radiating system, vented enclosure with rear firing flared port
● Drivers: Vifa Ring Radiator tweeter, custom 6.5″ long-throw aluminum cone woofer
● Crossover: 3.8 kHz, 3rd-order alignment
● Frequency Response: 50 Hz to 20 KHz (± 3 dB)
● Impedance: 6 Ohms nominal
● Efficiency: 89 dB (@ 1 watt / 1 meter)
● Power Rating: 25-120 Watts power handling
● Dimensions: 13.75″ H x 13.5″ D x 9.5″ W (349 x 343 x 241 mm)
● Weight: 24 lbs (11 kg) each; ship weight = 60 lbs (shipped in pairs)
● MSRP: $699/pair
jmck407
Re: AV123 Onix Rocket RS250 MK II pair
« Reply #1 on: 20 Nov 2021, 07:08 pm »
Pm sent.
