Odyssey Candela remote codes for Genesis MX-900 Universal Remote
brad1138
  • Don't forget to dance.... Don't forget to smile.
Odyssey does not appear in the list of supported brands in the MX-900 programming software.  All I need is volume up and down. Is it the same as another brand?
harley1952
Never had that problem but maybe calling the builder and ask them. They should know and if not tell them find out and get back to you.
It’s possible to do the transfer by using the remote that came with the gear and ur universal pointing them at each other, like in the old days.
klaus@odyssey
The remote board is Danish and doesn't act on codes...it's Alps specific.  However,  you can go with a learning remote without any problems
Chico Jim
  • Trust your ears
This may be a silly question, does each/every Candela come with the motorized Alps volume potentiometer? I ask as I recently found and bought a Candela that didn’t have a remote.  I love the unit and have it mated to a Niles SI-1230 amp unbridged with a pair of JBL 3677, and a B&W ASW300 sub.  It’s an amazing sounding system.  The CD player is Denon DVD-2930ci and my TT is an Audio Technica with a built in preamp.
Chico Jim
