Answer the “clock question”: Why your USB Cable might .. why it SHOULDN’T 😳
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
The measurements have been done as I'm sure you've done them too.
Thanks for the link.
WGH
A blind test is when you don't know the configuration, so that wasn't really a blind test.  What DAC?  Does it run from USB power?  Maybe the first cable was defective as far as the GND/+5V wires or connections.  USB cables don't change the data, so it can't be that.  If the data was erroneous, the DAC should mute.
I should have been more clear in my description. After troubleshooting the computer music server glitch I completely forgot I switched USB cables. The music server and USB/SPDIF converter are on the bottom shelf, none of the cables can be seen so there are no visual clues what cable is plugged in. It seemed like a blind test to me.
I use a Van Alstine Fet Valve Hybrid DAC with the SPDIF input plugged into a Kingrex UC384 Asynchronous USB/SPDIF converter powered by an Acopian Linear Regulated PS with 1.5 mV RMS ripple.
The music server USB out is handled by a Paul Pang USB 3.0 V2 card powered by a 5v Acopian Linear Regulated PS with 1 mV RMS ripple. The card uses the NEC uPD720202 chip along with a low jitter TCXO audio grade silver digital output transformer. The NEC uPD720202 chip is still used in current USB cards.
The +5v connection is not used in my setup, in fact the JMaxwell USB cable is data only with no power leg.
I watched the Audio Science Review "Do USB Cables Make an Audible Difference (Kimber Kable Review)?" but the title is misleading. The title should have been "Do USB Cables Make an Measurable Difference". The answer, as noted many times in the video, is no - they all measure perfectly. Ego, they all sound the same. Reminds me of a Julian Hirsch review.
I was hoping that Cherry USB or DAC DAC 2 customers would add their comments regarding USB cables but perhaps they are wisely keeping their heads down.
AmpDesigner333
<photos removed>
I’ll address your points more later, but thank you for taking the time to put your reply together.  Very well done!
Ripple is only one of many factors that determine power supply performance, but how various specifications affect the device being driven is dependent on the quality of the device’s design.  Only the highest quality designs will perform to spec with “junk power”, but just know that it’s possible.  My recent designs have multi-tiered power conditioning internally, so there’s no need to worry about a noisy power supply.
zoom25
Actually, I was going to go down the psychology path on this one.  Expectation bias, etc.  This is why fancy cable makers abhor double blind listening tests because 99% of the time they reveal charlatanism.
I've used stuff like the "jitterbug" (ironic name because it can't possibly affect jitter) to prove my point many times.  What I do is simply alternate then skip one switch, so the cables/devices are then the opposite.  Almost every time, the listener claims the benefits of the product they THINK is playing!  That's no joke.  It's actually difficult to reveal the results because people don't like being told they were fooled.
I think there are a lot of genuine bogus products that don't cause any change. In those scenarios, sure, the manufacturers would not prefer anyone do any such testing and in fact they will avoid discussion of the tech, specs, and measurements. That's certainly one group.
Although, I think amongst the collective of sensible customers and manufacturers who've been doing this for a long time, they generally do put out non-bogus products (i.e. they cause a change) and the customers generally can tell if they are certain YES, this is doing something vs. "guys, I think or feel like it may be doing something...but I think I'm shooting in the dark"
Perfect example (yet again) is of Jitterbug. I have 2 of these. Audioquest for example recommends that their primary use is in the chain (computer's USB output -> Jitterbug -> DAC). However, they've also recommended that you can plug in a second one to an unused port for further SQ improvement. I've always felt and written that Jitterbug in the chain with all of my DACs have caused some change in sound. However, when plugging a second one to an empty unused port and then plugging and unplugging it with the music playing, I don't feel much confidence that any change happens. Of course, not everyone will want to admit that or go through such experiments. Still, I think that amongst the more experienced and skeptical listeners/tech curious crowd, we do get a good handle on whether things make a difference or do not.
I've somewhat moved on from "whether things make a difference or not" from the early years of listening when I was still developing my listening skills and gaining testing experience. For the past few years, the more interesting for me has been "what does the difference mean"? In playback settings fidelity, neutrality, and accuracy in reproduction are a high priority for me. So when a product comes along that's supposed to be inert in its influence in the chain causes a change, I'm more interested in finding out whether the sound is now more or less accurate and whether this change toward more or less accuracy corresponds proportionally or inversely with my enjoyment or interpretation of SQ.
Make no mistake that I'm still skeptical of manufacturers (from boutique to even some big ones - including the 'big' one we have on this forum itself). I've asked them MANY times on this forum and elsewhere: why their products are sensitive to such changes and not immune currently and also what they could do to make things more immune to changes elsewhere. Responses can vary from "it shouldn't be happening", "I don't know", or "Use whatever sounds good"...rarely do I ever get a satisfactory explanation. BTW this wouldn't be a case of just myself imagining this. So many other customers would say the same thing and in fact the manufactures themselves will poll the customers what they think offers the best SQ or what's their "preferred" connection/arrangement (as to not make their product look bad).
It makes me question whether the manufacturers are aware of the full picture and are purposefully hiding the explanation to not make their products look bad, or whether they too are not fully aware of some of the aspects.
This is why I haven't bought a new audio product in over 5-6 years. So many new areas, such as network switches and stuff. Some will say that they make no difference. Meanwhile, other listeners and the manufacturer will say that YES there a difference AND it makes the SQ better. However, the problem arises when they can't explain the tech or provide any measurements. it's either 3 things:
1) They are knowingly lying outright.
2) They don't want to reveal their secrets, but are aware of the full picture.
3) They don't really have a full grasp of things.
I was astonished when I was reading some of the comments by the manufacturers of the EtherRegen during its development. One of them (superdad?) said that we don't fully understand all of it, but to our ears its an improvement over previous product, so we're still going to release it...I couldn't believe that. You are the manufacturer! You are the one group that should know. Otherwise, how can you say with confidence if whether any changes you cause are for the better and not for worse!?
I'll follow up on the blind testing and best practices for them, got to run for now.
