Klipsch RP-500M upgrade
0 Members and 1 Guest are viewing this topic. Read 1174 times.
Jason72
« on: 14 Nov 2021, 04:36 pm »
With the help of E-Zee (meaning I could not have put it together without him), I upgraded my third set of Klipsch speakers with Danny's upgrade kit. This was more difficult than the RP-504C and the RP-8000F due to space constraints. In the end, the tweeter and woofer circuit had to be on separate boards 4"x6" and 2 1/2"x5. I am betting the 4x6 could be more narrow and the other one a little shorter. Having separate boards with the space constraint also did not allow me to attach the boards and then install. I am not at the level of soldering inside a speaker, so I had two ins for both positive and negative lines.  I took a couple of pieces of small wire and twisted everything together to attach to the terminals. I still had fun despite the challenges and again, big thanks to E-Zee.
First attempt and it would not fit.
Part of the reason I could not side mount a single board.
Scraped glue and had to trim a couple of the braces on the bottom for the board.
Getting the boards ready to install.
Installed and ready for speakers.
Danny Richie
Re: Klipsch RP-500M upgrade
« Reply #1 on: 17 Nov 2021, 12:01 am »
Keep us posted.
Jason72
« Reply #2 on: 17 Nov 2021, 02:51 pm »
Keep us posted.
They sound great. They are less tinny or bright and now match up with my other upgrades. Music listening is better, less tiring and I can increase the volume to hear more detail without it sounding too loud (if that makes sense).
The second speaker was easier. I put the no-rez in first and trimmed one of the plastic legs on the input plastic housing (Klipsch has four that extent a couple of inches into the box and one was touching one of the inductors).  I also narrowed the board for the woofer circuit and that made for a better fit for the no-rez.
My media room is becoming 50/50 movies/music. Hanging out to watch a great movie or just relaxing and listening to music. I don't think I can do anything with the Klipsch rp-502s bipole side surrounds outside of disabling them if playing multi-channel stereo.
Thank you Danny for helping me take it to the next level.
Danny Richie
« Reply #3 on: 19 Nov 2021, 02:29 pm »
Wow, nice looking room.
Jason72
« Reply #4 on: 19 Nov 2021, 03:17 pm »
Thank you sir.  With your upgrades and help from you and members of this community, it sounds a lot better  :D
kyrio_s
« Reply #5 on: 15 Jan 2022, 08:43 pm »
If anyone is wondering - upgraded caps (Alumen Z-cap with Miflex bypass for tweeter and Gen I Sonicaps with Miflex for the woofer) and Mills resistors do fit!  They sound fantastic!
Oh, and I fixed the tilted inductor in the picture to be more of 90 degrees orientation.
