Well Tempered Classic motor noise
Ears Deluxe
« on: 11 Nov 2021, 03:02 am »
I've got a Well Tempered Classic with the round motor, and lately that motor has started to produce a clicking sound as it spins. It's not terribly loud and doesn't interfere with my enjoyment of the table, but I'm concerned that it might be a sign of trouble that could get worse. Does anyone have any experience with this? I'm thinking it may just be that the motor needs some lubrication, but I don't know where to apply that lubrication or what kind should be used. I'd appreciate any advice you might have.
cllogan
Re: Well Tempered Classic motor noise
« Reply #1 on: 8 Dec 2021, 04:59 pm »
Hello
Check the clearance on the spindle that holds belt could have shifted down and touching top of motor.
sHERO
« Reply #2 on: 17 Feb 2023, 12:32 pm »
If a new motor were needed, the relacment is a Hurst 3203-001.
