Ifi Zen Blue V2 question
0 Members and 1 Guest are viewing this topic. Read 2787 times.
I.Greyhound Fan
« on: 1 Nov 2021, 11:28 pm »
I am thinking about buying the Zen Blue V2 DAC so I can connect to my TV via BT and they run it into my main stereo system on occasion since I have 2 subs and for regular TV I just run 2ch through an old AVR.
My question is about the balanced 4.4mm out.  Is this just for headphones (which I suspect it is) or can you use a 4.4mm to dual XLR cable and connect it to the balanced inputs on my BAT preamp?
Larry
I.Greyhound Fan
Re: Ifi Zen Blue V2 question
« Reply #1 on: 2 Nov 2021, 05:51 pm »
I just found out the answer.  It is for connecting to a Balanced Preamp with XLR and not for headphones.
iFi David
  • iFi audio NEO Stream is here!
    • iFi audio
« Reply #2 on: 4 Nov 2021, 09:14 pm »
That's correct. It's a balanced line out, just disguised as a 4.4mm output as two 3-pin XLRs wouldn't fit in there :)
