0 Members and 1 Guest are viewing this topic. Read 12292 times.
Davey, An interesting note was that Jack from NHT said that time and overall phase is so subjectively hard to pick up that the tweeter/midrange was time aligned (from memory) "just because there was no reason not to do it". Kevin Voecks and many other excellent speaker designers have simply been unable to verify that phase/time is very audible, if at all, and Voecks has done some serious looking into it. But, like I said, digital makes it easy, so why not? Driver/cone distortion, dispersion and oth ...
Scotty/Davey,Thanks for confirming. I was pretty sure it was a single point. That is why I never understood sloped baffles. Simple geometry would tell you that that will only work for a single point, which is all well and good, but a different claim then often made by the manufacturers.Truth be told, if one is evaluating critically a speaker design then they should be in the listening sweet spot and not walking about the room. But if the speaker does its thing for a spot 8.8' away from the speakers and another listener happens to have his listening spot 9.2' away, what then? I guess that is why digital correction is such a cool thing, because it allows flexibility in the design to match the room and setup of the user, provided the user knows what they are doing. ...
With many speakers because of the high order crossover and the non sloped baffle the sound from the tweeter leaves the speaker before the other drivers and therefore makes a speaker seem more detailed, and most people like that. .
Wow this topic took off again.John Ashman - fancy running into you here Why do you say there is no cause/effect relationship between hearing disjointed treble to the 360 degrees of phase rotation in a 4th order crossover?
By design, isn't a non time and phase coreect speaker's treble disjointed? As well as the bass and midrange.?
