WTRP tone arm rewire what wire will fit in arm tube hole
Creed
Hi, I have a Well Tempered Record Player with silver arm that has been in closet for a while and want to use it or sell it. One way or another it needs a re wire. The stock wires are very thin. What tone arm manufacturers make a wire that will fit in the small hole on side of arm tube. I was looking at Zivfino, discovery, Cardas and some others but some may be to big. Has anyone had good luck with a wire that will fit. Or did you drill the hole larger. Any advise would be appreciated.
SteveFord
