Power Pipes™ in a 4-CHerry 😳🍒😎
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
« on: 25 Sep 2021, 05:44 pm »
uphoto
Re: Power Pipes™ in a 4-CHerry 😳🍒😎
« Reply #1 on: 28 Sep 2021, 09:52 pm »
Clean work!!!!
Early B.
« Reply #2 on: 29 Sep 2021, 12:16 am »
OK -- I'll be the one to ask -- what is that???
AmpDesigner333
« Reply #3 on: 29 Sep 2021, 04:55 am »
The copper pipes that connect power to the monoblock amplifier boards in the x-CHerry multi-channel amp series!
seikosha
« Reply #4 on: 29 Sep 2021, 11:39 am »
With all that exposed copper, do you need to worry about oxidation?
AmpDesigner333
« Reply #5 on: 29 Sep 2021, 12:30 pm »
Since the connections are soldered, the pipe may not be as shiny 10 years from now, but it will have the same ultra low resistance to the amps.
jtwrace
    • TIPP YouTube Channel
« Reply #6 on: 29 Sep 2021, 02:32 pm »
Seems like an odd way to do it given the performance of a well designed PCB.
AmpDesigner333
« Reply #7 on: 30 Sep 2021, 03:17 pm »
Received a question about the "why", and the answer's simple....  Ultra low resistance for the power that feeds the amps!
....and we thought of using a PCB since the original design was a motherboard with our 1kW Cherry "mini boards", then cards, then we graduated to something that's only doable with true craftsmanship.  This is no mass-market amplifier system!  This is Cherry  8)
AmpDesigner333
« Reply #8 on: 16 Nov 2021, 03:48 pm »
We have a KING 4-CHerry for sale, built and fully tested, but never used other than that....  Email [email protected] for info.  We also have some demo deals....
