Free Software for W10
0 Members and 1 Guest are viewing this topic. Read 2640 times.
« on: 22 Sep 2021, 11:06 pm »
After W10 was released they started modify it, one of the modifications was removing the bold font option from the system. with this people with poor eyesight were harmed among which myself, CHANGESIZE is a W10 System Font Size Changer and will increase and bold text size in Windows10 for free.
https://www.wintools.info/index.php/system-font-size-changer
« Last Edit: 23 Sep 2021, 12:14 am by FullRangeMan »
Re: Free Software for W10
« Reply #1 on: 22 Sep 2021, 11:19 pm »
DiskCheckup will verify health conditions from your hard disk drive when you run this excelent app.
https://www.passmark.com/products/diskcheckup/
« Reply #2 on: 22 Sep 2021, 11:28 pm »
I dont use Wi-Fi as its harmful to health, but this app can be useful for those who use, WirelessMon monitor WiFi hot spots in real time (free for trial, purchase $39).
https://www.passmark.com/products/wirelessmonitor/index.php
« Reply #3 on: 22 Sep 2021, 11:34 pm »
Glary Utilities will clear your PC + automated options.
Automated options are It will run scan just after power on by default amongs others features.
https://www.glarysoft.com/glary-utilities/
« Reply #4 on: 23 Sep 2021, 12:11 am »
PicPick is a superb substitute for the mediocre Paint, formerly PaintBox image editor, it does everything well in graphics design tools for free(no movie editor), go much beyond MS Paint, Iam using the free version 5.0.0 (paid version $30 single) I will not update to the new version available.
https://picpick.app/en/
« Last Edit: 23 Sep 2021, 01:47 am by FullRangeMan »
WGH
« Reply #5 on: 23 Sep 2021, 01:25 am »
Microsoft PowerToys: Utilities to customize Windows 10
https://docs.microsoft.com/en-us/windows/powertoys/
WGH
« Reply #6 on: 23 Sep 2021, 01:26 am »
WGH
« Reply #7 on: 23 Sep 2021, 01:31 am »
OlderGeeks.com
no ads, no crapware, no b.s.
We are a software download site without ads, fake download
3000 files and 400 games, all free
https://www.oldergeeks.com/index.html
« Reply #8 on: 24 Sep 2021, 03:08 am »
STDU Viewer free software to open multiple file formats documents.
http://www.stdutility.com/stduviewer.html
« Last Edit: 24 Sep 2021, 04:56 am by FullRangeMan »
« Reply #9 on: 24 Sep 2021, 03:13 am »
STDU Converter is a interesting free converter app, will convert files DjVu, TIFF, DCX, CBR or CBZ to PDF.
http://www.stdutility.com/stduconverter.html
Lite version:
http://www.stdutility.com/stduconverterlite.html
« Reply #10 on: 26 Sep 2021, 10:59 pm »
An alternative translator to Mr.Goo, very similar to him and even better in some details:
https://www.deepl.com/pt-BR/translator
There is a free version to download for PC.
« Reply #11 on: 4 Dec 2021, 08:20 am »
Using this add at FireFox v88, very useful and smooth it delete cookies just after the tab closed and inform you.
https://github.com/Cookie-AutoDelete/Cookie-AutoDelete
Cookie AutoDelete
Control your cookies! Automatically delete unwanted cookies from your closed tabs while keeping the ones you want.
Main Features
- Auto Deletes Cookies from Closed (and/or discarded) Tabs
- WhiteList/GreyList Support for domains
- Easily Export/Import your Whitelist/Greylist and core settings
- Clear All Cookies and site data for a Domain
- Supports Manual Mode Cleaning from the popup
- Easily See the Number of Cookies for a site
- Support for Container Tabs (Firefox 53+ Only)
goodvibrations
  • If it sounds good, turn it up to make sure!
« Reply #12 on: 18 Jan 2022, 03:51 am »
Two packages come to mind:
1) Audacity - an unbelievable audio reimagination tool. My use case is archiving vinyl both saving the audio into tracks and cleaning up the noise. It can do much more and is available cross-platform: https://www.audacityteam.org/
2) HWINFO64 - allows access to an incredible amount of hardware details including monitoring temps, fan speed, and most other system details. Free for personal use: https://www.hwinfo.com/
Enjoy!
« Last Edit: 18 Jan 2022, 11:01 pm by goodvibrations »
