Anything Bravo
0 Members and 1 Guest are viewing this topic. Read 5213 times.
Neo
Re: Anything Bravo
« Reply #20 on: 23 Oct 2021, 07:35 pm »
If you go with 3/4" + 1/4" thick panels, use a larger a roundover/radius on the left & right edges. The other edges aren't as important, but the top will help a little bit.
If you use 1/2" + 1/4" panels, you can use the standard recommended roundover/radius.
Thank you
Neo
Re: Anything Bravo
« Reply #21 on: 29 Oct 2021, 07:19 pm »
Can anyone confirm the inside Dimensions of the Bravo?
Looks like 10 1/2" High X 6" Wide X 10" deep.
« Last Edit: 31 Oct 2021, 03:50 pm by Neo »
Danny Richie
Re: Anything Bravo
« Reply #22 on: 3 Nov 2021, 02:16 pm »
Cabinet plans are on the site.
Neo
Re: Anything Bravo
« Reply #23 on: 29 Dec 2021, 02:34 pm »
Making progress, intermittent and slow but having fun and moving forward. Learning about woodworking and how to use new tools, All good. Using a Walnut, Hard Maple and Red Oak pattern applied to MDF. I'm still hopeful I can pull off creating an acceptable looking and sounding cabinet.
morganc
Re: Anything Bravo
« Reply #24 on: 29 Dec 2021, 03:14 pm »
Those are going to be stunning!
borism
Re: Anything Bravo
« Reply #25 on: 29 Dec 2021, 04:13 pm »
I love how the pattern plays with the eye creating a 3-D illusion!
Neo
Re: Anything Bravo
« Reply #26 on: 4 Jan 2022, 05:10 pm »
morganc, borism, thanks for the encouragement.
Neo
Re: Anything Bravo
« Reply #27 on: 23 Mar 2022, 11:49 pm »
Plan A Three D pattern was a failed effort. Gluing 1/4 inch cut hard wood end grain onto 1/2 inch MDF turns out is a real bad idea. The boards warped like lasagna noodles! All those clamps could not keep it all flat. A lot of work went into the dumpster. Should have just made a bunch of 3D Hard Wood end grain and cut them at 3/4 inch. A big time killer but Live and learn.
Plan B - 3/4 MDF with Cherry veneer. It is coming along, 2nd coat of oil based Satin clear varnish. X-overs soldered and ready for install. No-Rez applied. Can't wait to finish these so I can hear them.
« Last Edit: 27 Mar 2022, 04:34 pm by Neo »
Neo
Re: Anything Bravo
« Reply #28 on: 24 Mar 2022, 12:20 am »
Why do pictures upload sideways?
Any way to edit that?
Hobbsmeerkat
Re: Anything Bravo
« Reply #29 on: 24 Mar 2022, 12:49 am »
You need to edit them (i.e. crop them slightly) on your phone before uploading them. Or adding them directly to your gallery before sharing them here.
Neo
Re: Anything Bravo
« Reply #30 on: 27 Mar 2022, 05:35 pm »
I'll try posing pictures again that are orientated correctly. These have been rotated in Gallery.
« Last Edit: 27 Mar 2022, 06:55 pm by Neo »
Neo
Re: Anything Bravo
« Reply #31 on: 27 Mar 2022, 05:52 pm »
Need Tweeter gaskets. Tweeters sit slightly low.
Any suggestions on where to buy gaskets to correct how my tweeter sits in the cabinet?
Will this tweeter sitting a little low in the flange be noticeable if corrected?
Neo
Re: Anything Bravo
« Reply #32 on: 27 Mar 2022, 06:06 pm »
Playing Music. Been playing overnight to break in.
Neo
Re: Anything Bravo
« Reply #33 on: 25 Apr 2022, 02:45 pm »
Received a suggested solution for my gasket question from a Butch. Thanks for the idea.
